UR 10e Post Process Joint Value Error
When I try to process my programs from to robodk to my ur10e the values for the joints are off by ~5deg each and I am wondering if that is an issue of the way that I'm going about downloading it or if there is something I can do to combat this.
I have tried running UR_LoadControllerKinematics with a program from our robot that has worked in the past and get this error. (see img 1)
Would love some insight on these issues and thank you for your help!
I have also read about people being able to upload urp files to robo dk and that doesn't seem to work either. When I try to do that I get the same error.
I read a forum that said to make sure that the robot was correct which I did. I made a new station, uploaded the correct robot, and tried again to no avail. I also tried updating robodk and that also did not work.
Could it be something with URSim?
Thanks for the help,
WS
attachment for previous post
Attached Files Image(s)
Did you generate the URP file using your UR robot controller? (not RoboDK or URSim)
I recommend you to follow the steps outlined in this section:
https://robodk.com/doc/en/Robots-Univers...Kinematics
Or simply load the URP file in RoboDK.
If it still fails, can you provide us with the URP file you are trying to load?
Yes,
I just read through the article you linked. I followed the steps and while it did help a little bit the robot was still off by about an inch.
Here is the urp file being used.
.urp   CompleteCleaning6.24.21.urp (Size: 101.43 KB / Downloads: 733)
