UR3e Robot Base Reference Frame Incorrect
See attached picture. The reference frame for the UR3e seems to be located in an arbitrary location.
RoboDK v3.6.0 (64 bit)
EDIT: Updated to latest version (3.8.4) and issue still persists. The issue is also present with the UR3 robot as well.
Attached Files Image(s)
I attached the updated Universal Robots UR3 and UR3e.
This parameter can be manually fixed in the robot parameters menu. I also recommend you to follow this procedure to import robot kinematics in the simulator:
https://robodk.com/doc/en/Robots-Univers...Kinematics
.robot   UR3e.robot (Size: 2.19 MB / Downloads: 1,103)
.robot   UR3.robot (Size: 758.02 KB / Downloads: 942)
