04-26-2021, 11:13 AM
Hi
I'm unable to modify any of the post processors included in RoboDK, I've tried to open them in RoboDK and manually with Python IDLE, but I only receive the following message:
Any help would be appreciated.
# -*- coding: UTF-8 -*-
# Copyright 2015-2020 - RoboDK Inc. - https://robodk.com/
# This file loads the compiled version of the RoboDK post processor for:
# Epson RC robot controllers
# More information about RoboDK Post Processors and Offline Programming:
# https://robodk.com/help#PostProcessor
# https://robodk.com/doc/en/PythonAPI/postprocessor.html
import sys
import os
# Detect Python version and post processor
print("Using Python version: " + str(sys.version_info))
path_app = os.path.dirname(__file__).replace(os.sep,"/")
print("RoboDK Post Processor: " + path_app)
# Check if the post is compatible with the Python version
version_str = str(sys.version_info[0]) + str(sys.version_info[1])
path_library = path_app + '/v' + version_str
if not os.path.isdir(path_library):
raise Exception("Post Processor not found. Make sure you are using a supported Python version: " + path_library)
# Load the post processor
print(version_str+ ".Epson_RC import*")
exec("from v" + version_str + ".Epson_RC import *")
if __name__== "__main__":
test_post()
