Unable to modify post processor
Hi
I'm unable to modify any of the post processors included in RoboDK, I've tried to open them in RoboDK and manually with Python IDLE, but I only receive the following message:
# -*- coding: UTF-8 -*-
# Copyright 2015-2020 - RoboDK Inc. - https://robodk.com/
# This file loads the compiled version of the RoboDK post processor for:
#   Epson RC robot controllers
# More information about RoboDK Post Processors and Offline Programming:
#     https://robodk.com/help#PostProcessor
#     https://robodk.com/doc/en/PythonAPI/postprocessor.html
import sys
import os
# Detect Python version and post processor
print("Using Python version: " + str(sys.version_info))
path_app = os.path.dirname(__file__).replace(os.sep,"/")
print("RoboDK Post Processor: " + path_app)
# Check if the post is compatible with the Python version
version_str = str(sys.version_info[0]) + str(sys.version_info[1])
path_library = path_app + '/v' + version_str
if not os.path.isdir(path_library):
   raise Exception("Post Processor not found. Make sure you are using a supported Python version: " + path_library)
# Load the post processor
print(version_str+ ".Epson_RC import*")
exec("from v" + version_str + ".Epson_RC import *")
if __name__== "__main__":
   test_post()
 Any help would be appreciated.
If you have a licence you can ask RDK for an uncompiled version of the post
If you own a RoboDK Professional license, you can contact us by selecting Help-Request support in RoboDK.
You can then ask for the post-processor your need to edit.
