i have a small simulation(see attachment). When I create the program for the robot, I only see the instructions for the Mitsubishi. Where are or how can I get the instructions for the linear axis?
Is it possible to program a Kuka linear axis and a Mitsubishi RV7 robot synchronously online with RoboDk?
First, you need to set the direction of the external axis properly.
By default, RoboDK considers the linear rail will move along the X-axis.
As you use the Y-axis instead, you need to change that option.
For now, our post-processor for Mitsubishi du not support external axes, but we can add it.
Do you have an example program where the Mitsuvbshi controller drives an external axis?
It can be a simple small piece of code where you use MoveJ and MoveL with the external axis.
02-02-2021, 07:55 AM (This post was last modified: 02-02-2021, 09:10 AM by thomas.)
HI Jeremy,
thanks for your answer and your help. No, I do not have an example. Im a newbie to roboDK and also to robots :-)
I work in the research & development department of an automotive supplier. In our department we need a way to measure planar and curved shapes. During my research I found roboDk on the internet. This seems like a promising approach to me. Unfortunately, I'm running out of time as I only have 30 days to test roboDK. Perhaps an extension of the trial time is possible?
The linear axis came to mind to save some space, as we have to measure surfaces that are about 1.4m long. Similar to the above attached example. I didn't want to use a suitably large robot.
BTW, with the trial version it is not possible to edit the parameters.
