I've created curve follow projects in RoboDK for sanding which works great, however with some of the angles of the workpiece and the size of the sanding head, there are inconsistencies with pressure and finish quality.
So, I've inserted the RoboDK generated UR script under a Force node in the UR teach pendant. With tool force selected and in the Z axis.
It mostly works ok, but when doing the Approach and Retract movements, I could do with not having torque for these movements. I could manually edit the script into 3 and insert the required force code before and after the main sanding part (after Approach completed), but we're looking at letting our client be able to create new programs as easy as possible without having to edit code.
Has anyone achieved using force torque with generated RoboDK script?
