Virtual Reality
Hello, Currently we are using Dell Visor VR headset with RoboDK. We were able to connect the head set and visualize the robot. For some reason the Robot appearance in VR is on the floor rather than at eye level (I have to look down to see the Robot). I am not sure how to change the projection so the Robot or scene appear right in front of it. Any help in this regard is appreciated. Thanks.
Can you share the RoboDK project file you are using?
You may need to place the coordinate system of the robot at the Z level at 0 mm.
(01-11-2023, 04:24 PM)Albert Wrote: Can you share the RoboDK project file you are using?
Thanks. See attached.
The station was not attached properly. Don't forget to click the "Add Attachment" after you choose your files!
