Windows11 v5.3 Bug
Hello
My OS is Windows 11.
I have upgraded v5.25 to v5.3.
In v5.25, when click 'Show camera' on the set camera  after App drop down.
When I contacted the dealer, it seems that it worked fine on Windows 10.
To debug this issue it would help if you can follow these steps:
  1. Close RoboDK
  2. Start RoboDK by double clicking the file:
    C:/RoboDK/RoboDK-Debug.bat
  3. Try to reproduce the problem in RoboDK until it crashes.
  4. Right after the crash, provide us with this file:
(10-08-2021, 07:13 AM)Albert Wrote: To debug this issue it would help if you can follow these steps:
  1. Close RoboDK
I have attached the file.
Thank you for your support.
.txt   RoboDK.debug.txt (Size: 8.29 KB / Downloads: 827)
Thank you for the file. It looks like you loaded an RDK file that provoked the crash. Can you provide us with the RDK file?
(10-11-2021, 09:20 AM)Albert Wrote: Thank you for the file. It looks like you loaded an RDK file that provoked the crash. Can you provide us with the RDK file?
I have attached the RDK file.
Japanese is also included.
Best regards
.zip   CamraTest_20211007_test.zip (Size: 2.44 MB / Downloads: 814)
I'm unable to reproduce this issue on Windows 10.
Did you have issues with RoboDK v5.2.5 on Windows 11?
Can you provide more information about how to reproduce the crash?
You can find older versions of RoboDK here:
https://robodk.com/whatsnew?Dw
[attachment=2652 Wrote: P0.png    Albert pid='10473' dateline='1634035815']I'm unable to reproduce this issue on Windows 10.
v5.2.5 works fine on Win11.
v5.3 on Win11
Select camera show menu.
App will drop.
Strange... Can you try placing the camera to the root of the station? (attached to the station item)
You can still link the camera to the TCP.
Do you still see a crash?
