Yaskawa MT1 500 model
Two things wrong with robodk model.
1: Turn direction on this model is wrong. From yaskawa, stock setup is the opposite from robodk.
When model moves clockwice, the robot moves ccw, vice versa.
Yaskawa say I can change this in the controller but that it: "will affect other parts of the expected operation"
Tilt is correct.
2: Mounting face plate is 45 degrees wrong. Angle of the 4 outer holes on the front(top) face is from stock setup 0 90 degrees and not 45 45 degrees. photos will follow. This can be changed in 'Robot/home position/absolute data' on the controller, but it is not the way stock yaskawa robots are set up.
Thank you for sharing these details!
You can set the rotation direction on the Robot panel - Parameters - Unlock advanced options - Joint senses :
Alternatively, you can right-click on the robot - Modify robot - Invert axis :
Also, you can adjust the flange model position:
I attached the corrected Motoman MT1 500 S2HD model.
.robot   Motoman-MT1-500-S2HD-md.robot (Size: 1.26 MB / Downloads: 452)
Thanks Sergei!
