12-24-2020, 03:47 PM
hello
is it possible to upload loaddata et wobjdata from a existing program abb ?
abb import tooldata wobjdata |
hello
12-24-2020, 08:37 PM
Hi Raynald,
It's possible. Load the right robot in your station. Drag and drop the .mod file to RoboDK. Select "Import Program (Pose Targets)" In the imported program, find the "Set tool" and "Set Frame" instructions On each one, right-click -> "Select Tool" or "Select Reference" The tool and reference frame should be added to your station. You can do the same with the targets. Jeremy
(12-24-2020, 03:47 PM)raynald Wrote: hello hello again it is a simple abb s4 with tool and wobkdata but it seem to not detect ? [attachment=1727 Wrote:
12-28-2020, 02:06 PM
Hi Raynald,
You need at least one MoveL for it to work. I just added a dummy MoveL to your program (the MoveL needs to use the tool and frame) and it worked perfectly. Jeremy
12-28-2020, 07:23 PM
OK I SEE
I THOUGHT IT WORKED SO WHEN YOU PARSE THE FILE AND YOU FIND TOOLDATA OR WOBDATA ROBODK CREATE TOOL A THE FLANGE ROBOT 5HOLD TCP° A WOBJ A THE BASE ROBOT IT WILL BE A GOOD OPTION FOR EVERY BODY |
| 1 Guest(s) |
