acquire waypoints form a PLC
Hello
im am currently working on a project which requires Robodk to acquire robot waypoints through a PLC,
is there any other methods/modules to setup communication with a PLC apart from the Python and a Modbus library,and the post processor suggested in the above answer ?
related previous post
PLC MODBUS COMUNICATION
Hi Jimmy,
Does an OPC UA server work for you?
More info here: https://robodk.com/forum/Thread-OPC-UA-i...hlight=OPC
(11-06-2020, 12:07 PM)Jeremy Wrote: Hi Jimmy,
thank you for the prompt reply
my current project requires to pickup and object with a UR5e robot arm, from a mount that is connected to an actuator,and the actuator which is controlled through a PLC.Our plan is to input the position of  the actuator to Robodk and use the path planning/simulation of the object pickup task.
if my understanding is correct from,it is possible to acquire positions through a PLC with OPCUA support.
I assume it requires the PLC to be OPCUA compatible,in the case its not ,is there another methods that you would recommend for the above men mentioned you would recommend ?
Hi Jimmy,
Apart from building a solution using one of our API (Python, C#, C++), no there's no built-in feature to do so.
Pretty much anything can be integrated to RoboDK using our API though.
