issue of Connection to UR5e
I would like to connect RoboDK to an UR5e to run some programmes.
First, I put in the IP and it showed that 'Ping to *** (IP)  SUCCEEDED'.
Secondly,  after clicking 'connection', it showed 'waiting' and the log file said
'*** (IP):30000 Can't connect to ***(IP):30002 to send program
Can't start client program on robot...'
For this, I managed to allow RoboDK to communicate through Windows Defender firewall. But it still did not work.
I am wondering if you may advise? Cheers!
Did you enable remote mode on the Teach Pendant?
(02-13-2023, 03:41 PM)Alex Wrote: Did you enable remote mode on the Teach Pendant?
Yes. I did.
I just realised that this UR5e did not have any IP shown in 'About' of the Teacher Pendant. Perhaps I misunderstood the IP shown in MODBUS. Do I need to connect Ethernet to the UR5e controller first?
I managed to connect and ping RoboDK with UR5e via Ethernet using static addresses. It looks better but still shows 'waiting' only after clicking 'connect'. The log file said
'Server established: ***.***.0.1:30000
Connected to ***.***.0.2:30002. Sending program :/progrobodk.script...
Updating computer IP on program: ***.***.0.1
Updating computer port on program: 30000
Program sent.
Waiting...'
I am wondering what this message means and what I should do at this point? Thank you for your advice.
I checked the log file in UR teaching pendant and attached the photo here.
It looks like RoboDK is connected to UR but could not take any action. I am wondering if you may advise what the issue is and how to sort it out?
Cheers
Is the connection status in RoboDK showing "Waiting..." ?
Can you provide us with the log messages you see in RoboDK?
(02-28-2023, 11:08 AM)Albert Wrote: Is the connection status in RoboDK showing "Waiting..." ?
Hi Albert, Thank you very much. Yes it shows 'waiitng...'. Log file is attached below
Sending command...
Available local IP addresses (IPv4):
192.168.0.1
Server established: 192.168.0.1:30000
Connected to 192.168.0.2:30002. Sending program :/progrobodk.script...
Updating computer IP on program: 192.168.0.1
Program sent.
Waiting...
The above is what happened when running from my working laptop which IT already allowed apiur to communicate through firewall (we cannot turn firewall off though). Today I just tried the same method using my personal laptop and found that everything worked smoothly including connection to UR5e and running RoboDK programm using driver. I can see the log file there having some lines which never showed up in my working laptop:
Starting robot driver: C:/RoboDK/api/robot/apiur.exe
Starting...
RoboDK driver for UR v3.9.0
So I came to the conclusion that there is still something blocking RoboDK in my working laptop (even I ran RoboDK as admin). It would be very helpful if you could advise.
Also, I would like to run Robotiq vacuum gripper directly from RoboDK in laptop. It would be much appreciated if you could refer to the relevant document/tutorial/guidance for doing this. Cheers!
