variables between scripts
I need to share variable between scripts in order to increment values... is it possible?  In particular I need to share variable to increment value inside python script (check attached image)
let me know your suggestions
best regards
You can use Station parameters to store data and retrieve it through the API.
They can also be set in an Program instruction.
More info here: https://robodk.com/doc/en/PythonAPI/robo...k.setParam
