Borunte Robot Arm Project setup
#21
We haven’t tried it via FTP, but we’ll try, but it won’t work to launch the program via FTP. The task is to launch the program. Thank you very much for your answer!
#22
Hello, I just want to ask to PythomSpace Borunte robot works fine with RoboDK, I am thinking to purchase a Borunte robot. Thank you!
#23
What do you mean by PythomSpace? Is this a Borunte robot model?
#24
Hello, PythonSpace was the member who started the post :-) I would like to know if all Robodk features work fine with a Borunte robot, in that case I would purchase a Robodk license and a Borunte robot. Thanks 👍
#25
You should be able to test the integration between RoboDK and Borunte robots using the free/trial license. Let us know if you have any issues generating programs.
I'm not sure if this user will see your message.
#26
Thank you for your reply Albert, I already have the RoboDK trial version and I like it, I don't have the real robot yet but I will get one. Best regards
#27
That sounds good, let us know if you need any help.
#28
Hello Albert, I am trying to generate the program for Borunte robot but it doesn´t work, I attach the station and the error message. It is a simple program with two targets, Borunte 2110A robot and the library spindle. Thank you!
.rdk   Borunte test.rdk (Size: 1.35 MB / Downloads: 363)
#29
Please change the tool name to 'Tool 1'.
This is specific for the Borunte controller and it is necessary that the tools in the RoboDK station are numbered.
#30
I have changed the tool name to "1" (only number, no letters in it) and now it can generate the program, why can´t I write "tool_1"? thank you for your attention
