75
Hi Jacob,
Note that you can import many CAM program file format, for example .nc, .gcode, .apt .
Simply drag and drop them in a RDK station with a robot, a tool and a reference frame.
Have a great day.
226
Hi Marco,
I recommend you to use the following remote path:
md:/
This is the default value. Let me know if you have any issues.
Threads: 1
Dear Albert,
I tried the path you suggested, but still nothing is sent to the robot.
Do you have any other idea what could be wrong?
Kind regards,
Marco Withag
226
Are you able to send files through FileZille?
Maybe you don't have write permission via FTP?
226
If you can send files through FileZilla it means it should work. What error message do you see in RoboDK?
I would recommend you to close FileZilla when you send the program to your Fanuc controller from RoboDK in case that 2 connections provoke issues.
Threads: 1
I got it up and running!
I think there was indeed a problem with having filezilla connected at the same time as RoboDK.
The Remote FTP path that is working for me is \md:
Thank you all for the great help!
Kind regards,
Marco Withag
