Can’t find starting point in 3D Printing
Not sure what's the problem here. I have the correct TCP orientation
Can you share your RoboDK project file? What is it that you are trying to accomplish?
I'm trying to print this stl box using my robot
.rdk   PrintingFinal.rdk (Size: 18.17 MB / Downloads: 508)
(Updated file attached)
.rdk   (2)Two.rdk (Size: 23.83 MB / Downloads: 522)
It looks like you are trying to use a 4-axis robot arm. It will be challenging to accomplish this task. You should properly align the coordinate system and the tool to make your robot work like a 3-axis CNC.
I see, is there any tutorial on how to do so?
You can find some examples here:
https://robodk.com/doc/en/Example-3-Axis...ining.html
3D printing, curve follow projects and robot machining are handled very similarly with RoboDK when it comes to converting a path into a robot simulation and a robot program.
Hello Albert, I could do the 4 axis so I reduced it to 3 axis but it's still giving me an error can you help me with?
Can you share your RoboDK project file? We can better help you.
