Can not "Load Curves" into RoboDK
Deutsch================
[Q]: Die allgemeine Anforderung bestand darin, zwei Laufwege auf der 3D-Dateioberfläche zu definieren. Die entworfenen Wege werden dann in RoboDK geladen. Es ist jedoch kein Problem, die Teile 1, 2, 4 und 5 einzuführen. Beim Laden von Teil 3 oder 6 wird das "Coordinate System" jedoch erstellt.Sie werden jedoch nicht in RoboDK geladen.
[Bitte]: Was muss ich tun, um die Line 3,6 erfolgreich in RoboDK einzuführen?
English=================
[Q]: The general requirement was to define two paths on the 3D file surface. The designed paths are then loaded into RoboDK. It is not a problem to load Curves 1, 2, 4 and 5. However, when loading part 3 or 6, the "Coordinate System" is created. However, they are not loaded into RoboDK.
[Please]: What do I need to do to successfully load Curves 3,6 into RoboDK?
.stp   Werkzeug-AFP-V3.stp (Size: 127.77 KB / Downloads: 556)
Is this SolidEdge?
Can you save it in the CAD file native format and send it to us?
We will try to see what's going on on our end.
(12-01-2021, 03:59 PM)Jeremy Wrote: Is this SolidEdge?
yes. I will send it to you tomorrow. Thank you very much!!
I've gotten the CAD file from my assistant coach. He drew the drawing using catiaWerkzeug-AFP-V3.catpart.I hope you can help me find the problem, thank you very much.
Hi Jahna,
Sorry for the misunderstanding, I meant the SolidEdge file. With the paths you are trying to import.
It seems to be more of an issue with our plugin than anything else.
(12-07-2021, 02:30 AM)Jeremy Wrote: Hi Jahna,
Well, it's already attached to my web site. I hope very much to hear from you soon. Link:[Werkzeug.par]
I sent that link to my dev, we'll see what we can do about it.
If you try to load just 3 or just 6, does it work?
If so you could merge them with the others within RDK.
I try to load only 3 or 6, also can't load.
Jhana
Weird, I don't currently have SolidEdge, so I can't really give it a try.
I'll wait to see what my dev finds.
Ok, thanks all the same. Very hopeful that this can be resolved soon.
Jhana
3 Guest(s)
