Correct Robot Model and Post-Processor for Yaskawa MH50 with DX200?
Hello.
I am relatively new to RoboDK.
I have a Yaskawa MH50 k00 630kg 50kg payload robot.
What is the correct name for this robot in RoboDK, and which post-processor should I use when the controller is a DX200?
Best Regards
Stig Lindberg.
We have the following Motoman MH50 robot:
[/url][url=https://robodk.com/robot/Yaskawa-Motoman/MH50]https://robodk.com/robot/Yaskawa-Motoman/MH50
You can use the standard Motoman or Motoman Cartesian postprocessors.
For the standard Motoman postprocessor, the pulse/degree ratio values should be updated by loading the ALL.PRM file into the RoboDK station.
You can find additional info at the following link:
https://robodk.com/doc/en/Robots-Motoman.html#Motoman
Thank you for the help.
Then I add the ALL.PRM file from the robot I get this Python Error, I have added a picture to this thread.
Attached Files Image(s)
Please make sure you are using the latest version of RoboDK and the Tools - Options - Python tab uses the default Python interpreter:
If that doesn't work, we can apply your ALL.PRM file to the MH50 robot and post the updated robot here.
(10-01-2024, 11:55 AM)Sergei Wrote: Please make sure you are using the latest version of RoboDK and the Tools - Options - Python tab uses the default Python interpreter:
Hi again.
I have tried to follow your instructions.
I am running Python 3.12.6, but I still get the same Python error when I try to open the ALL.PRM file.
Should I post my ALL.PRM file here?
You can try doing this with Python-Embedded.
Quote:Should I post my ALL.PRM file here?
Yes, of course. You can post it here.
Alternatively, you can contact us at info@robodk.com.
(10-01-2024, 06:11 PM)Sergei Wrote: You can try doing this with Python-Embedded.
I have contact you on email.
We sent you an updated robot.
