Hello everyone. I am working on a project where I have a table with two degrees of freedom, created with two different mechanisms, and a 6-axis robot. I need to connect robot and table through external axes but I have a problem: when I get the screen to connect the table with the robot it gives me the possibility to choose only one type of table mechanism and not both. How can I solve the problem?
External axes - How to synchronize a 2 axis positionner |
10-06-2023, 08:37 AM
You should model the external axis as one single unit before synchronizing it with the robot arm. If can share your RDK project we can help you better.
10-13-2023, 01:44 PM
It's necessary to use a '2 rotative axis' kinematic template for such kind of 2-axis positioner, instead of a nested '1 rotative axis' :
Here is a station example with the robot and 2-axis positioner: https://robodk.com/example/Machining-and...ith-ABB-02 You can find more information about the creation of the mechanisms in RoboDK below the link: https://robodk.com/doc/en/General-Create...ModelRobot |
| 1 Guest(s) |
Powered by MyBB
