Failure to Drag and Drop ALL.PRM
I tried to drag and drop a Yaskawa ALL.PRM file as per the online instructions. I keep getting this error
"Python script failed returning - 1073741515
Python script output"
And the Robot Parameter file does not update.  I am running RoboDK V5.2.4.20742.  The robot is a Yaskawa GP110 running YRC1000. I tried attaching the ALL.PRM file but it was not allowed.
You may need to install Python 2 and make sure it is available in the path. We'll remove this dependency in the near future.
Automatically extracting the pulses/degree ratio from Yaskawa/Motoman ALL.PRM files is new in RoboDK and should work if you selected the correct robot. More information here:
https://robodk.com/doc/en/Robots-Motoman...omanPulses
(08-10-2021, 11:31 PM)Albert Wrote: You may need to install Python 2 and make sure it is available in the path. We'll remove this dependency in the near future.
Thanks it worked.
