11-10-2026, 07:30 AM
Hello RoboDK Team,
Following previous discussions with Raphael Voyer regarding Smart Motion and external-axis applications, one of our customers evaluated Smart Motion as an alternative to Collision Free Planner.
During the evaluation, the customer confirmed that Smart Motion can successfully generate avoidance paths using Joint Targets and Constrained Space, including applications with an external axis.
While implementing the solution through the RoboDK API, the customer encountered the following questions.
We have two questions regarding Smart Motion and the RoboDK API.
Question 1: Constrained Space Control
We confirmed that Smart Motion can successfully generate avoidance paths when Constrained Space is enabled.
However, we could not find a way to enable or disable Constrained Space through the RoboDK API.
We tested the following PluginCommand names:
- setConstrainedSpace
- getConstrainedSpace
- onConstrainedSpaceClicked
- ConstrainedSpace
- constrainedSpace
- chkConstrainedSpace
All of them returned "Unknown command".
Questions:
1. Is it possible to control the Constrained Space option through the RoboDK API?
2. If so, which API method or PluginCommand should be used?
Question 2: Pulse per Degree Parameter
We investigated the effect of changing the robot's Pulse per Degree parameter.
We observed the following:
- The Pulse per Degree setting affects the output generated by RoboDK's standard post processor.
- However, changing the same setting had no effect on the output generated through our RoboDK API workflow.
- We could not find any API method that retrieves the Pulse per Degree values.
Questions:
1. Does the RoboDK API use the Pulse per Degree parameter?
2. If so, which API functions reference this parameter?
3. Is it possible to retrieve the Pulse per Degree values through the RoboDK API?
Environment:
- RoboDK 6.0.1
Thank you very much for your support.
- ConstrainedSpace
- constrainedSpace
Questions:
Questions:
Environment:
- RoboDK 6.0.1
