06-26-2020, 03:17 PM
Does the Gcode import work with 7th axis and how does it process the moves?
Assume robot reach is 1000mm
7th axis is 2500mm (X axis)
If the Gcode is a path 2000mm on X axis will RoboDK use the 7th axis simultaneously?
Or in CNC concepts will it run as a true 5 axis or will it be a 3+2 and step the 7th axis.
Ideally the video here shows the goal but was that programmed or was it through the Gcode import/plugins. https://www.youtube.com/watch?v=3Soa9VjOeDg
