How to determine the time duration per instruction?
Hi, how can I determine the time duration that an instruction will take according to simulation?
E.g. I have a program with a few move instructions, I would like to determine the required move time for each separate instruction.
Related: can I separately execute the simulation of an individual instruction that is part of a program, and get a notice when done? If so, could I then use robodk.robomath.tic() and robodk.robomath.toc() before and after to measure the passed simulation time?
Maarten
Hi Maarten,
You can get an estimate for the whole program using the API: https://robodk.com/doc/en/PythonAPI/robo...tem.Update
I do not know of a built-in way to get a per-instruction estimate.
You can add a program call in between instructions to a Python script that logs the time, but this in itself will change the cycle time.
You can also monitor the robot and log the joints and timings, see this example: https://robodk.com/doc/en/PythonAPI/exam...tor-joints
