01-24-2024, 05:23 PM
Hi Guys
I hope you are well :)
I have build a robot cell, and it seems to be working fine, untill i transfer the program to the robot, then it goes wrong
ISSUE:
When i upload the program to the robot it tries to reach a possition in the carthesian frame, that it cannot, even though it looks right in RDK
Im pretty sure it is a minor detail im missing somewhere, so i hope you will take a look at it, and hopefully you can figure out what i have messed up :)
When i move the robot in "WorkFrame1RDK" space. if i move the X Axis, it moves in the X direction, but the coordinate on the robot frame it is the numbers for the Z Axis that moves, not the X Axis (Like the axis for the manipulator is set to)
Here is what i have tried:
But if i transfer the targets in Joint configuration (MoveJAbs) then there is no problem, and the robot moves where it is supposed to move. it is only in the carthesian coordinates i have the problem.
I have attatched the .rdk file
Thanks in advance
/Michael
RobotCelle1_12012024_139130.rdk (Size: 4.6 MB / Downloads: 532)
ISSUE:
- I have tried to redefine the TCP, no effect, it is basicaly the same place as it is now, and with the same orientation
- I have tried with the TCP redefined, to define the working frame "WorkFrame1RDK" No change
- I have made sure that all the frames are pointing in the same direction as the robot's frame, with the exception of the manipulator it self (The frame for the manipulator is pointing the right way)
Thanks in advance
/Michael
