Is there a way in RoboDK using Python to create a program that generates trajectories without any collisions? The problem is that I'm testing different functions like MoveL, etc., but of course, the robot moves to the point and then a collision occurs, so the robot stops. Is there a way to detect collisions without actually moving the robot, so that a collision-free trajectory can be generated without stopping the robot?
Is it possible to check for collisions before running the robot? |
05-07-2025, 11:32 AM
The MoveL_Test and MoveJ_Test functions can help you check if a movement is possible (including collision checking).
You can find some examples that move a robot through a set of points here: https://robodk.com/doc/en/PythonAPI/exam...easibility If you want automatic collision avoidance you should then use our Collision-Free planner plugin. You can find more information here: https://robodk.com/addin/com.robodk.plug...reeplanner |
| 1 Guest(s) |
Powered by MyBB
