01-13-2021, 04:58 PM
KUKA - Linear Move |
01-29-2021, 02:58 AM
Sorry for the delay. Could you try the attached driver and let me know if it fixes the problem? Simply unzip it in "C:/RoboDK/api/Robot" Jeremy
02-01-2021, 05:49 PM
Hi Alumill,
I have another potential solution for you, could you try activating this option here: Jeremy
03-11-2021, 04:18 PM
Sorry for the late answer. The new driver does not fixes the problem, same behavior. I have made a workaround that works for me: - I removed the synchronization between robot and rail - If I want to move the rail, I do RunCodeCustom with the X-coordinate of the rail but I have another problem with that, see code: Code: def MoveRail(X):Second problem: I can not read the position of the rail, that's why I manual set the joints of the rail. Is it possible to get feedback from the RunCodeCustom?
08-13-2021, 04:09 PM
I have encountered the same problem with linear movements using a KUKA and a 7th linear axis. Has a solution to this problem been found? Thank you in advance, Adam
08-17-2021, 10:52 AM
Did you read this new section of the documentation: https://robodk.com/doc/en/Robots-KUKA.ht...ADriverExt
08-17-2021, 09:16 PM
Jeremy,
I have read the documentation like you suggested and I have implemented the fixes. Still no luck :/ Adam |
| 1 Guest(s) |
Powered by MyBB
