Is it possible to calibrate my robot manually? I do not have access to a CMM machine or a laser scanner,
Is there any other way to calibrate the robot? Set up a jig with known points and have the robot move to those points?
224
12-07-2018, 09:06 PM
(This post was last modified: 12-07-2018, 09:07 PM by Albert.)
By default, robot calibration works with a measurement system and you can have the calibration fully automated by using RoboDK's robot drivers and a supported measurement system.
It is not possible calibrate the robot using a jig in a user friendly way in RoboDK but we may be able to help you integrate such jig as a measurement system in RoboDK.
How do you calibrate your jig? How accurate is it?
I assume you are using/targeting calibration for collaborative robots only?
You can send us an email if you want to go more into details:
info@robodk.com
Threads: 5
How could I calibrate using a manual template or reference points inside the welding cell?
