09-02-2025, 06:22 AM
I am using the demo version – unfortunately RoboDK only provides zero joint angles. Is there any way to enable this, or do I need to upgrade to the full version?
Missing Joint Angles on Export |
09-03-2025, 10:08 AM
Do you mean that when you try to generate a robot program you see all joint values set to zero?
If so, I assume you are using a Yaskawa/Motoman robot controller. Yaskawa/Motoman robots require entering the pulses/degree ratio to properly generate programs for their robot controllers. You can find more information here: https://robodk.com/doc/en/Robots-Motoman...omanPulses You can also use the Motoman Cartesian post processor to generate Cartesian targets (which do not depend on the pulses/degree ratio). |
| 1 Guest(s) |
