Modifying robot axis geometries
Is it possible to modify the links of robots from the robot library? Can you add geometry to the links (i.e. cables, etc.)?
Yes, you can add geometry to existing robots by following these steps:
https://robodk.com/forum/Thread-Attach-a...7#pid10617
You can also model your robots from scratch:
https://robodk.com/doc/en/General.html#Model6axis
You can also dynamically attach objects to robot links using https://github.com/RoboDK/Plug-In-Interf...tachObject
