Motoman Post Processor doesn't ouput position coordinates
I just recently started working with RoboDK so I might be missing something here:
I work with a Yaskawa Motoman GA50 with an YRC1000 controler. After creating a test file for the robot I was trying to export the program (.JBI) using the default Motoman post processor but all my position values are 0.
If I use  the Motoman Cartesian post processor it outputs values properly but this this format gives me an syntax error message on my YRC1000. (see attachments)
Is there anything I am missing or could this be a bug in the post processor?
Korbi
Robot setup.JPG    program with Motoman Cartesian post processor.JPG    program with default Motoman post processor.JPG
.rdk   PG_EXP.rdk (Size: 2.06 MB / Downloads: 394)
To properly generate programs for Motoman robot controllers you should properly update the pulses/degree ratio of your robot arm. This is needed to convert the joint values from degrees to pulses.
You can update the pulses/degree ratio by double clicking on the robot and selecting Parameters. You can also do this automatically by loading the ALL.PRM file you can find on your robot controller.
https://robodk.com/doc/en/Robots-Motoman...omanPulses
If you want to use base, you may want to turn off mframe from the post.
You could go the other way and use only userframe and not base. I would make the userframe (2 in your case) on the robot and not with P values, at least I have never had success doing it this way.
I switch between pulses and userframes all the time depending on the job.
Dear Albert,
Thanks for your reply
I tried to automatically load the ALL.PRM file into RoboDK but i keep getting a python error message (see attachments). It seems like I cannot attach the ALL.PRM here, but I could send it via E-Mail if that would help?
Or would there be alternatives to extract the Pulse/Degree data and all the other relevant info of the GA50 so I can set everything up properly in RoboDK?
thanks for the suport!
If you can share the ALL.PRM file, we can update the pulse/degree data on our end and share the modified robot with you.
I sent the file via Email to info@robodk.com
Please let me know once you had time to take a look at it.
Thanks a lot
Please find the robot attached
.robot   Motoman-GA50.robot (Size: 1.41 MB / Downloads: 401)
It works like a charm!
Thanks a lot Sergei for the help!
Following up to my previous question, is it also possible to extract the Pulse/Degree for the Positioner (DF500) from the ALL.PRM file? I found some values for the positioner in the forum but they seem to be slightly off.
I re-sent the ALL.PRM file to the info@robodk email and I'm attaching the current Station template here in the attachments
Thanks again for the help,
Korbi
.rdk   GA50_D500F_Working_Template.rdk (Size: 3.05 MB / Downloads: 384)
Unfortunately, it's not possible to read external axes data from the ALL.PRM file.
As an option, you can copy these values from the controller teach pendant.
