Move joints doesn't work
Question
''Move joint'' don't work.
I try to connect Robodk to a Kuka robot, ''Get position'' work well but ''move joints'' stay ''working.. (in yellow)''. see picture attached.
I don't know if there is a relation between that and the compilation errors displayed on robot when is started.
Robot: Kuka KR 6 R700 sixx
Robodk version: v3.5.4 (64 bit)
processed-a0a36560-29f2-4928-ba22-5358ebe8e31f_XnTlG5FD.jpeg    processed-2f3098ed-46f6-464c-88ed-fb3c6337ebab_fTn8wJGJ.jpeg    processed-938d32d9-cd3c-4455-8332-a4a00d44d1dc_8qlCPdZa.jpeg
You probably need to follow this procedure to establish the communication between the robot controller and RoboDK:
https://robodk.com/doc/en/Robots-KUKA.html#DriverKUKA
(10-27-2021, 01:25 PM)Albert Wrote: You probably need to follow this procedure to establish the communication between the robot controller and RoboDK:
I follow all steps but RoboDKsynch.src program is not running.
there is two path to $config.data
path1 : KRC/R1/STEU/config.data (at the same STEU folder, there is a DATA folder included $option.data end $costumer.data)
path2: KCR/STEU/config.data (at the same STEU folder, there is a DATA Folder included $option.data $costumer.data $machine.data $option.upg $costumer.upg $machine.upg)
 I modified both of them (added declaration)
but after some seconds the Config.data in the path2 come like that:
&ACCESS  RV
&PARAM DISKPATH =
&REL 2
DEFDAT  $CONFIG
INT COM_ACTION=0
REAL COM_VALUE1=0
DECL E6AXIS COM_E6AXIS
DECL POS COM_POS
DECL FRAME COM_FRAME
ENDDAT
I tried to manipulate the STEU folder in the second path but I can't do it . it's said that the folder is open in a other program
Did you try to power down and power up the controller to get access to the STEU folder? (it could free it from use).
(10-28-2021, 03:13 PM)Jeremy Wrote: Did you try to power down and power up the controller to get access to the STEU folder? (it could free it from use).
Yes, I do it
No change,
See pictures attached about errors in customer.data and option.data files in repertory R1/STEU/Mada
It like there is two programs how generate the same configuration, but I don't know how to verify that
