OpenCv CharUco Calibration
I am having trouble to get accurate pose estimation for the robot using OpenCV.
The calibration returns a sub-pixel reprojection of .05.
However, the positioning when searching for the marker is off by a few mm.
import cv2
import numpy as np
import cv2.aruco as aruco
from robodk.robomath import Mat
from robodk.robolink import *
board = cv2.aruco.CharucoBoard(
    size=(5,7),
    squareLength=0.035,
    markerLength=0.021,
    dictionary=cv2.aruco.getPredefinedDictionary(cv2.aruco.DICT_6X6_100)
picture_range=15
RDK= Robolink()
Poses = [RDK.Item(f'Target {i}') for i in range(1, picture_range)]
for i in range(1, picture_range):
    globals()[f"Pose_{i}"] = RDK.Item(f"Target {i}")
camera= RDK.Item('Cali')
robot = RDK.Item("Doosan Robotics H2515")
robot.setSpeed(1000)  # mm/s
robot.setAcceleration(1000)  # mm/s²
if not camera.Valid():
    print('CAMERA NOT FOUND')
    exit()
calibration_file = "C:/Users/skha/PycharmProjects/GolfPutty/CalibrationFiles/calibration.xml"
def chaUco_Calibration(calibration_file):
    # Detection setup
    # Calibration data collection
    all_corners = []
    all_ids = []
    image_size = None
    calibration_complete = False
    detector = aruco.CharucoDetector(board)
    while True:
        for i, pose in enumerate(Poses):
            robot.MoveJ(pose)
            # Get frame
            bytes_img = RDK.Cam2D_Snapshot("", camera)
            if not bytes_img:
                continue
            nparr = np.frombuffer(bytes_img, np.uint8)
            frame = cv2.imdecode(nparr, cv2.IMREAD_COLOR)
            cv2.imwrite(f"C:/Users/skha/PycharmProjects/GolfPutty/CalibrationFiles/{i}.png", frame)
            if image_size is None:
                image_size = frame.shape[1], frame.shape[0]
            # Detection
            frame = cv2.cvtColor(frame, cv2.COLOR_BGR2GRAY)
            # Detect ChArUco board
            charuco_corners, charuco_ids, marker_corners, marker_ids = detector.detectBoard(frame)
            if charuco_ids is not None:
                frame = cv2.aruco.drawDetectedMarkers(frame, marker_corners, marker_ids)
                frame = cv2.aruco.drawDetectedCornersCharuco(frame, charuco_corners, charuco_ids)
            #display_text = "Press 'c' to capture calibration frame"
            #key = cv2.waitKey(1)
            all_corners.append(charuco_corners)
            all_ids.append(charuco_ids)
            print(f"Captured frame {len(all_corners)}")
            # Calibrate when enough frames (press 'f' to force)
            if ((len(all_corners) >= picture_range)) and not calibration_complete:
                print("Calibrating...")
                ret, mtx, dist, rvecs, tvecs = cv2.aruco.calibrateCameraCharuco(
                    all_corners, all_ids, board, image_size, None, None)
                if ret < 1:  # Good reprojection error
                    fs = cv2.FileStorage(calibration_file, cv2.FILE_STORAGE_WRITE)
                    if not fs.isOpened():
                        print("Error: Unable to open file for writing. Check file path and permissions.")
                        exit(1)  # Stop execution
                    fs.write("Camera_Matrix", mtx)
                    fs.write("Distortion_Coefficients", dist)
                    print("Calibration complete and uploaded to RoboDK!")
                    print(f"Reprojection error: {ret:.2f} pixels")
                    return
                else:
                    print(f"Poor calibration (error: {ret:.2f} px). Capture more frames.")
            # Display info
            #cv2.putText(frame, display_text, (10, 30),
            #            cv2.FONT_HERSHEY_SIMPLEX, 0.7, (0, 255, 0), 2)
            #cv2.putText(frame, f"Frames captured: {len(all_corners)}/15", (10, 60),
            cv2.imshow('ChArUco Calibration', frame)
            if cv2.waitKey(1) & 0xFF == ord('q'):
                break
    cv2.destroyAllWindows()
if __name__ == "__main__":
    chaUco_Calibration(calibration_file)  # Only runs when executed directly
More pictures and xml:
Position  and code:
[Image: e1d4b6f7c35ff89bb3e31f5aeeab9d5a0988eaee_2_520x500.png]
RoboDK .rdk file attached
0.png    1.png    2.png    3.png    4.png    5.png    6.png    11.png    12.png    13.png    14.png    15.png    board reprojectiomn.PNG
.py   Step 1 Calibrate Camera File.py (Size: 4.16 KB / Downloads: 397)
.py   Step 4 Move Robot to Marker.py (Size: 6.81 KB / Downloads: 383)
.rdk   GolfPutty.rdk (Size: 1.76 MB / Downloads: 453)
I am currently looking into your issue and would need more information to properly find the root problem. Would you be able to tell us which version of OpenCV you are currently using? I would also recommend trying to spread out your targets for calibration more.
Raphael
OpenCV 4.12.0.88
The XML file is not attached. Could you share this file as well? It may help us understand what's going on.
For your information, you can find our official example to calibrate a 2D camera using a chessboard here:
https://robodk.com/doc/en/PythonAPI/exam...#camera-2d
