Parameter setting in "curve follow project" for 7 axes
Do you have an example or teaching video of 7 axes path? The robot is coupled with a spindle placed horizontally. The spindle rotates and the robot performs linear reciprocating motion above.
In "curve follow project", I am confused about the "axes optimization" commands, and always going to error. Prompting: "the robot cannot reach all targets in the path". So I want to know how to choose proper parameters in my case.
Hope to get your help
This example shows how you can use external axes for robot machining and curve follow projects:
https://robodk.com/doc/en/Plugin-Mecsoft...MExample5x
You can find the RDK project file here:
https://robodk.com/example/Machining-and...-with-KUKA
(03-16-2023, 11:37 AM)Albert Wrote: This example shows how you can use external axes for robot machining and curve follow projects:
Hello, ALbert, thanks for your reply.
I already check the examples in the link,but none of them use the "axes optimization" command,it can't give me valuable reference.
Another problem is that if i don't choose "axes optimization",it will prompt “cannot find start point”.
But my path is simple and normal vector defined, Hope you can check my setting.
I 'd like to attach my file,please have a look.
.rdk   test5.rdk (Size: 3.42 MB / Downloads: 569)
This robot was modeled in a very strange manner. Delta theta for joint 4 in the DH table was set to 360 deg but it should have been set to 0. It is better if you contact us to add new robots.
I attached an image with the edits I made to fix the issue and to be able to move along the path.
.rdk   test5-v2.rdk (Size: 3.81 MB / Downloads: 591)
