02-02-2024, 09:40 PM
I have a 6 axis robot arm and 2 axis positioner table. The CAD has them positioned approximately correct, but I need to dial it in further, within 1mm.
The only way I seem to be able to adjust the axis of rotation of the positioner table relative to the 6 axis robot arm is by 1) calculating the positional offset from 180 degree rotations, 2) removing the sync between the two systems, then 3) manually adjusting the positioner table top level reference frame.
Is there a better way to calibrate the positioner table relative to the robot arm? The calibration tool for a turntable will create a reference frame at the intersection of the tilt and rotation of the positioner, not at the positioner table base.
