Python: Panel Control
Hey guys,
im using Python to control the robot. Is it possible to move the robot in one direction (for example [0,0,1] by saying start moving and stop moving, like using a control panel. I've tried the python example for the key control but in real life the robot is not moving very smooth because it's stopping after every step.
Thank you!
Yes this is possible. If you use the RoboDK API you should make sure you call the setRounding instruction before your movements:
robot.setRounding(round_mm)
This allows the robot to smooth corners.
More information here:
https://robodk.com/doc/en/PythonAPI/robo...etRounding
Of if you use the GUI:
https://robodk.com/doc/en/Robot-Programs.html#InsSmooth
Can you share the code you are trying to run?
What robot are you using?
