I installed the new update of RoboDK on my MacOS laptop but when launching, it raises an error (image enclosed). I run a MacBook Pro 2015 with the latest version of MacOS.
Actually, RoboDK for Mac version is still 4.0.1. Updated version for Mac will be available later this week.
Does it work if you run it without user settings?
(Double click the file: RoboDK-Skip-Settings.sh)
If so, you can probably start RoboDK without any issues by removing all the RoboDK user setting files in:
Home/Library/Preferences/com.robodk.*
You can use CMD + Shift + . to display the Library folder.
In any case, you can follow these steps so we can fix this crash:
Go to the RoboDK install folder (usually home/RoboDK/).
Run the RoboDK-Debug.sh file (double click it). See image attached.
After the crash, provide us with this file:
RoboDK.app/Contents/MacOS/RoboDK.txt
Application Specific Information:
dyld: launch, loading dependent libraries
Dyld Error Message:
Library not loaded: /Users/*/Documents/*/libSense_LC.dylib
Referenced from: /Users/USER/*/RoboDK.app/Contents/MacOS/RoboDK
Reason: image not found
Model: MacBookPro12,1, BootROM 187.0.0.0.0, 2 processors, Dual-Core Intel Core i5, 2,7 GHz, 8 GB, SMC 2.28f7
Graphics: kHW_IntelIris6100Item, Intel Iris Graphics 6100, spdisplays_builtin
Memory Module: BANK 0/DIMM0, 4 GB, DDR3, 1867 MHz, 0x80CE, 0x4B3445364533303445452D45474346000000
Memory Module: BANK 1/DIMM0, 4 GB, DDR3, 1867 MHz, 0x80CE, 0x4B3445364533303445452D45474346000000
AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x133), Broadcom BCM43xx 1.0 (7.77.106.3 AirPortDriverBrcmNIC-1435.3)
Bluetooth: Version 7.0.1f1, 3 services, 27 devices, 1 incoming serial ports
Network Service: Wi-Fi, AirPort, en0
USB Device: USB 3.0 Bus
USB Device: Bluetooth USB Host Controller
Thunderbolt Bus: MacBook Pro, Apple Inc., 27.1
Here is the screenshot
There is no RoboDK.txt in the directory but there is a RoboDK executable which send the same output as in the screenshot
I'm getting a different error on MacOS
dyld: Library not loaded: /Users/a/Documents/LC2_1125/标准版/src/libSense_LC.dylib
Referenced from: /Volumes/SPINRITE V6/Applications/RoboDK/RoboDK.app/Contents/MacOS/./RoboDK
./RoboDK-Debug.sh: line 3: 39072 Abort trap: 6 ./RoboDK -DEBUG
