04-14-2020, 01:36 PM
Im refreshing this post since my problem is similar to described here.
I also had problem with config file but this is now solved thanks to this thread.
Im connecting to KRC4 compact and ping is working, Windows defender disabled.
Im using Windows 10 and RoboDK 4.2.3
On Kuka Im running Kukavarproxy 9.0.0 I also tried v6.1.101 with the same result.
I think I have problem on the PC side.
1. I tried to install vcredist_x86 2008 - but it said I have a newer version installed on my PC (I had Visual Studio 2013 installed previously to use for Beckhoff PLC), then I installed vcredist_x86 2013.
2. After I couldnt connect I found out two error messages about missing dlls:
-Qt5Core.dll
-Qt5Network.dll
I downloaded these from the net and loaded to my system32 folder.
3. After I tried to connect there is error:
apikuka.exe Couldnt find insert point
Cant find insert point procedure ??0QMutex@QEAA@XZ in C:\WINDOWS\SYSTEM32\QT5Network.dll
Im attching sreen from the details of my connection in RoboDK.
My quess I have bad dll drivers for this Kukaapi
I will try to use my old Win 7 computer for that but I will first have to bring it from the office - I need couple days foir that so I thought in the mean time meybe there is a solution for that.
Thanks in advance for any help.
Tom
-Qt5Core.dll
-Qt5Network.dll
Tom
