Surface scanning
Hello there
I want to scan a flat piece of 100x100 mm with 5 mm intervals. Should I do it by adding a target point to each point. Is there a short method for this process.
You may try to use the Surface Pattern Generator Add-in (SPG):
https://robodk.com/addin/com.robodk.app....ngenerator
Do you have a tutorial for the Surface Pattern Generator?
I have a curved surface and its not easy to get good results.
Having trouble with the Reference frame orientation.
Thankyou.
This sample station shows how to use the surface pattern generator Addin:
https://robodk.com/example/Painting-with-KUKA-KR-5-arc
The scripts in the station perform the same operations you can do using the Addin's UI.
We'll try to better document the Surface Patter Generator Add-in in the documentation and let you know.
Thanks this is a little helpful. But I still need more instruction as my CAD part has curve in 2 directions and is orientated with 3 angles in space. I will keep playing around with the program and experimenting things to make some progress and get better results.
You can find the documentation of the surface pattern generator Addin here:
https://robodk.com/doc/en/Addin-Surface-...rator.html
Let us know if something remains unclear.
Okay Thanks Albert.
This information is useful for using the plug-in.
Have a good day.
Thank you for your feedback.
