12-08-2019, 03:26 PM
(This post was last modified: 12-09-2019, 08:10 PM by Albert.
Edit Reason: Added Python code in a Code box
Hi everyone,
I'm doing a project where i want to click on a single point of an image and get the coordinates (x, y, z) of that point in real life. Then recreate on robodk the scenario of the camera and move a robotic arm (ur5e of universal robots) to that point. The thing is that if i print the coordinates (x, y, z) that i get from the camera, i think they make sense, but when i use them to create a target for robodk and move the arm there, they don't match with the point where should it go.
This is the code that i'm using.
If someone knows how to get the rotation of the camera, it would be very useful too.
Thanks in advance,
Regards.
import cv2 # state of the art computer vision algorithms library
import numpy as np # fundamental package for scientific computing
import imageio
import matplotlib.pyplot as plt # 2D plotting library producing publication quality figures
import pyrealsense2 as rs
import win32gui
import win32api
import time
import pyautogui
import tkinter
import tkinter.messagebox
from robolink import * # API to communicate with RoboDK
from robodk import * # basic matrix operations
# Any interaction with RoboDK must be done through
RL = Robolink()
top = tkinter.Tk()
points = rs.points()
pipe = rs.pipeline()
config = rs.config()
profile = pipe.start(config)
colorizer = rs.colorizer()
align = rs.align(rs.stream.color)
state_left = win32api.GetKeyState(0x01) # Left button up = 0 or 1. Button down = -127 or -128
device = profile.get_device() # type: rs.device
depth_sensor = device.first_depth_sensor() # type: rs.depth_sensor
if depth_sensor.supports(rs.option.depth_units):
depth_sensor.set_option(rs.option.depth_units,0.0001)
robot = RL.Item('UR5e')
frame = RL.Item('Frame 2')
Target = RL.AddTarget('Target 2', frame)
try:
while True:
frames = pipe.wait_for_frames()
frames = align.process(frames)
depth_frame = frames.get_depth_frame()
color_frame = frames.get_color_frame()
if not depth_frame: continue
#print(width,height)
depth = np.asanyarray(colorizer.colorize(depth_frame).get_data())
color = np.asanyarray(color_frame.get_data())
images = np.hstack((color, depth))
#cv2.namedWindow('RGB_View', cv2.WINDOW_NORMAL)
#cv2.setWindowProperty('RGB_View', cv2.WND_PROP_FULLSCREEN, cv2.WINDOW_FULLSCREEN)
cv2.imshow('RGB_View', depth)
depth_intrin = depth_frame.profile.as_video_stream_profile().intrinsics
#flags, hcursor, (x,y) = win32gui.GetCursorInfo()
x, y = win32api.GetCursorPos()
#print(x, y)
pixel_coord = [x, y]
keypressed = win32api.GetKeyState(0x01)
key = cv2.waitKey(1)
# Press esc or 'q' to close the image window
if key & 0xFF == ord('q') or key == 27:
cv2.destroyAllWindows()
break
#Calculate distance
if keypressed!=state_left:
state_left = keypressed
print(keypressed)
if keypressed < 0:
if (0<x<632 and 32<y<512):
dist_to_center = depth_frame.get_distance(x,y)
dist_to_center = round(dist_to_center, 4)
depth_point = rs.rs2_deproject_pixel_to_point(depth_intrin, pixel_coord, dist_to_center)
depth_point = [i * 100 for i in depth_point]
depth_point = [round(i, 5) for i in depth_point]
#depth_point = ( ", ".join( repr(e) for e in depth_point))
#with open('Coordinates.txt', 'w') as f:
# f.write("%s\n" % depth_point)
#f.close()
print(depth_point)
print('The camera is facing an object:',dist_to_center,'meters away')
Target.setPose(Offset(eye(), depth_point[0], depth_point[1], depth_point[2], 0, 0, 0))
robot.MoveJ(Target)
time.sleep(0.7)
finally:
pipe.stop()
Thanks in advance,
Regards.
