Wrong position get with Motoman SIA20D
I generated a JBI which move robot to RoboDK defined home position, and then run the job on robot pendent.
Base on the position info of pendent, the robot moved to correct position without problem.
But if I use the "Get position" function to get the current position from robot controller, the position changed to as "Home_Robot" position as shows in the station project.
.jbi   ROBODKTEST.JBI (Size: 556 bytes / Downloads: 945)
.rdk   RoboDK_test_Home_2.rdk (Size: 6.39 MB / Downloads: 1,133)
Hi there,
did you take a look at this section of our Online documentation?
https://robodk.com/doc/en/Robots-Motoman.html#Motoman
(11-07-2019, 07:40 PM)Jeremy Wrote: Hi there,
Do you mean the "Update Pulses per degree information" section?
Due to we were using free version, so we cannot change the settings in this part.
Best regards.
Pence
If you are a company, just send me an email at jeremy@robodk.com
I'll send you a 30-days fully unluck license, you'll then be able to change these parameters.
Base on the testing result, the pulse/degree settings of J4 of Motoman SIA20D should change from -1149.156 to -1024.
Best regards.
Pence
Hi Pence,
Thank you very much for your feedback. We just updated the pulses/degree for the Motoman SIA20D as you suggested and updated the robot in our library.
Let us know if you need more help.
.robot   Motoman-SIA20D.robot (Size: 6.41 MB / Downloads: 1,118)
