Yaskawa Motoman GP25 pulse to degree
Hi.
I am a beginner of RoboDK SW, and I am trying to use yaskawa gp25.
I found that GP25 controller sends the pulse data, not joint angles, and I don't know the exact parameters to convert pulse to degree or versa.
I referred to the site below but still doesn't work.
https://robodk.com/forum/Thread-Pulses-p...ee-Yaskawa
Is there any way to check the exact pulse to degree parameter of GP25 ?
And where is ALL.prm file ?
Thank you !
Did you read this section of the documentation?
https://robodk.com/doc/en/Robots-Motoman.html#Motoman
Especially this sub section: https://robodk.com/doc/en/Robots-Motoman...omanPulses
(09-07-2022, 02:01 PM)Jeremy Wrote: Did you read this section of the documentation?
Thanks for your reply.
I loaded GP-25 robot in RoboDK, and checked 'Robot Parameters'.
The default values of 'pulse/degree' are all '1'.
What I referred the manual that you attached, the pulse/degree values are for motoman MH5F, not for GP25.
I tried to find 'ALL.PRM', but can't.
Is there any way to check the detail values of 'pulse/degree' for motoman GP25 ?
Apparently I cant access the parameters with the program trial so I am unable to test this myself.
I believe the directions are saying to load the All.PRM file from your own robot backup, so step 1 would be to make that robot backup.  Then add in the GP25 from the library and drop the ALL.PRM file in.
