5 axis robot
#11
Hi Ricardo,
You can simulate a 5 axis robot by making a 6 axis robot and locking out the extra axis, but instead of putting 0 in the axis limits, you can put a very small number so that RoboDK is able to solve the kinematics.
Note that this will enable the Alt + Left click movement of the robot in the x and z axis, but you will still need to move the J1 manually to "move" in the y axis.
Olivier
.robot   Scorbot-2.robot (Size: 292.72 KB / Downloads: 847)
#12
I have a similar problem with the Mitsubishi RV-2AJ.
I am able to move it, but when I create a milling program its not able to calculate it.I like it to ignore the axis around the spindle which is a 90 degree offset to the robot head.
#13
(04-17-2019, 05:54 AM)Jeremy Wrote: Hi there,
I tried a bit and didn't achieve better results than you.
RoboDK does not support custom 5 axis robot building, but it is worth the try.
Do you own a professional license? If it's the case, we can build it for you using our intern tools.
Hi Jeremy,
I have the same issue with my 5-axis robot arm. I built the robot by "locking" the 4th joint but I can't move it with Alt + Left click.
I own a professional license and I would like you to build the robot for me with your intern tools.
Best,
Filippo
#14
Can you attach the CAD models or send them to us at info@robodk.com, citing this post?
