5 axis robot
5 axis.png    Is it possible to create a robot with 5 axis?
Hi fmontemayor,
We don't have an option to directly create a 5 axis robot.
However, you can create a 6 axis robot and put the 5th and 6th axis at a distance of 0 mm and then limit the rotation of the 6th axis to 0 degree. In other words, you just ignore the 6th axis.
That should do the trick.
(Btw I never tried it, I'm just telling you what I would try.)
Thanks Jeremy,
Please review the robot, move it with Alt + Left click it's not possible
Regards
.robot   Scorbot 2.robot (Size: 291.3 KB / Downloads: 1,013)
Hi fmontemayor,
At the moment, it's totally normal. The way you built the robot, it's impossible for RoboDK to calculate the Inverse Kinematic of the robot.
I really don't understand what you did with your axes 4, but it's not cutting it mathematically speaking.
Did you try what I suggested you with the axes 5 and 6?
(03-18-2019, 05:15 PM)Jeremy Wrote: Did you try what I suggested you with the axes 5 and 6?
Yes.
I tried several configurations, but the problem is the orientation of axis 4
Can you help me build the robot, please?
Hello
I added the files
.zip   Scorbot ER-9.zip (Size: 2.05 MB / Downloads: 1,008)
Hello
Please confirm if the uploaded files are correct?
Fernando
Hi there,
I tried a bit and didn't achieve better results than you.
RoboDK does not support custom 5 axis robot building, but it is worth the try.
Do you own a professional license? If it's the case, we can build it for you using our internal tools.
Hi Jeremy
Thank you for your answer.
I have an educational license with the name of Universidad Autonoma de Nuevo Leon.
The robot is for academic use only.
I plan to use robodk to program the Scorbot ER-IX robot in the robotic laboratory.
Have a great day,
Fernando
(04-17-2019, 05:54 AM)Jeremy Wrote: Hi there,
Do you own a professional license? If it's the case, we can build it for you using our intern tools.
I'm also a student with the same problem configuring the Scorbot-ER IX to RobotDK.
Did RobotDK managed to sort it out ?
Ricardo Lopes
