08-29-2023, 12:54 PM
(This post was last modified: 08-29-2023, 01:19 PM by kyle_kepley.)
This feature is not clear in both the documentation and the user interface. From the robot control panel, when I double click on the angle values at either end of the jog sliders, a window pops up with 7 different angle values (on a 6 axis robot). There is nothing showing what each of these values represents. When changing the base joint there is a different window with a horizontal row of values that correlate to the robot in a more predictable way, but for the other joints there is a 2x7 grid along with a graph and nothing makes any sense. Even on the base joint pop-up only the first box appears to control the limit, I have no idea what the other five values do. A grid that shows the min and max angles for each joint where you could change these values would make a lot more sense, but this doesn't seem to be the way it works.
