Failed to connect Yaskawa Motoman SIA 10D with RoboDK
hello,
this my first time using roboDK and i use roboDK for my project. i use Yaskawa Motoman SIA 10D with DX100 as controller. i wanna connect the robot with my laptop. i already set the LAN setting, with my computer IP 192.168.255.9 and robot IP 192.168.255.1. i success doing ping in cmd with the robot. but when i wanna ping and connect from roboDK to robot, it said failed. and i allready turn off all connection except LAN connection. do you any suggestion for me?
Thank you
Take a look at our Motoman driver documentation, please:
https://robodk.com/doc/en/Robots-Motoman...verMotoman
Can you also provide us with the connection log?
(08-10-2023, 06:31 AM)Sergei Wrote: Take a look at our Motoman driver documentation, please:
i already follow the instruction manual from that link.
i tried it again, and success to ping in roboDK but still cannot connect.
here's the log
Disconnected
Stopped
Starting robot driver: C:/RoboDK/api/robot/MotomanHSE.exe
Starting...
ErrorSMS:RoboDK driver for Motoman v4.8.3 (HSE and Serial)
Loading settings: C:/Users/FARHAN AFIF/AppData/Roaming/RoboDK-Drivers/MotomanHSE.exe.ini
Default Tool ID: 0
Default Joint Speed (mm/s): 10
Default Linear Speed (mm/s): 5
Big Endian communication: No
Number of external axis 0
External axis control group 1
External axis control group is base: False
Robot control group 1
Serial timeout: 250 ms
Serial pause: 25 ms
SERIAL_BAUD: 9600
SERIAL_DATA_BITS: 8
SERIAL_PARITY: 2
SERIAL_STOPBITS: 1
SERIAL_FLOW_CONTROL: 0
Not connected
Sending command...
Using high speed ethernet protocol.
Connecting to E-Server
Working...
Using 7 axis arm
Using 0 external axes
Using system with 7 axes
Working...
Connection problems
Sending command...
Working...
Using 7 axis arm
Working...
Connection problems
Sending command...
Working...
Using 7 axis arm
Working...
Connection problems
Sending command...
Working...
Using 7 axis arm
Working...
Connection problems
Sending command...
Working...
Using 7 axis arm
Working...
Connection problems
Sending command...
Working...
Using 7 axis arm
Working...
i already use python 3.7 if we reffer to this link
https://robodk.com/forum/Thread-Can-t-connect-to-robot
Did you set the switch to remote on the teach pendant?
This issue should be unrelated to Python settings.
yap, i see it.
i moved it into remote mode on the pendant before i start to connect it.
I followed according to the instructions in this link
if we look at the log, this part,
Starting...
i think there is trouble with the driver, motomanHSE.
do you any idea?
thank you
Do you have the Motocom option?
You can try with the apimotoman driver instead:
  1. Select Connect-Connect robot
  2. Select More options...
  3. Click on Select right beside the Driver path
  4. Select apimotoman
This requires the Motocom license provided by Yaskawa/Motoman
i dot have motocom,
but i have motoPlus.
could i use motoplus instead?
We currently don't have a version of the Motoman driver compatible with MotoPlus.
Is there any way that i could controll the robot with motoplus using the data and programming from roboDK? I mean like export the program from roboDK and import to motoplus.
