Guidance for executing the project
Hello Albert Sir !! Recently we are working on one new project where we are looking for forming the sculpture shape by using a Fanuc 2000ia-210f robot and the spindle motor (6 kW) with 10 mm of tool for thermocol material. this system consist of one 7th axis (Rotational Axis).
Please go through the attached   environment I created for the same  and please guide us to generate program for this application.
Also please specify whether the educational license supports this seventh axis control.
Please guide us to give the demo at customer site. Once we prove them by showing demo then they will definitely buy the license.
Please go through the attached file for better clarification.
.rdk   Machining Process.rdk (Size: 1.17 MB / Downloads: 537)
.pdf   STF60-103-6.0-ER32-Wire box will be used (1) (1).pdf (Size: 126.63 KB / Downloads: 642)
You can find information about how to model a turntable here:
https://robodk.com/doc/en/General.html#Model1x
And you can find more information about how to load robot machining files here:
https://robodk.com/doc/en/Robot-Machining.html
Please note that educational licenses should only be sold to universities for educational purposes.
