I am trying to open and close my gripper which is not supported by RoboDK (Ufactory Gripper G2). I was told I could insert code to be executed, which I did (see Prog6 in the attached RDK file). When I run on robot, the moves execute, but the added code that I inserted to open and close the gripper is not executed.
If I generate the robot program and copy and paste the code from VSCodium into Ufactory Studio and run it, the program works (gripper opens and closes). Why does it not work when running the program from RoboDK with the Run on Robot selected? This is a major detriment to debugging as I can't use my gripper at all.
Also, and much less important... when I select Send Program to Robot, it does not get put on my robot... where does it go and how do I get it to the robot?
Yes, when I export the program with the " robot.UARMAPI.set_gripper_g2_position(pos=80, speed=100, force=100, wait=True)" complete with the indent (spaces) command in it, copy it into Ufactory Studio and run it, it does work. The gripper does open and close properly. However, in debugging a program (any program) in RoboDK using "run on robot" the command does not execute on the robot (gripper does not open or close).
I would expect when running on robot to step through my program, when it hits this inserted code command it would execute on the robot... it does not. This is a major hindrance to building and testing a program, one of the major advantages of RoboDK. I need to be able to actuate the gripper within RoboDK as I step through my program. How do I do that?
Can you test with this new version for Windows? This will allow you to run the robot.UARMAPI commands properly the same way you do with the post processor.
I have a consistent problem with running Prog7 for the first time, both in RoboDK 6.0.6.26902 and 6.0.7.26916. I connect to the robot and then run Prog7 for the first time. The robot makes the first move and then stops,. The connection status says working for like 60 seconds and then goes back to ready. It never completes the moves (I waited several minutes to make sure). I disconnect from the robot, move the robot back to the home position using Ufactory Studio, then reconnect to the robot in RoboDK and rerun Prog7. This time it actually completes all the moves, but the gripper never opens or closes. When the program completes, it says working for over a minute before going back to ready... but I can now run the program over and over (but the gripper never opens or closes).
The driver log files from both 6.0.6 and 6.0.7 are attached, and as you can see the joint move calls, but no calls are made to open or close the gripper.
I downloaded the RDK file you provided and ran it. It failed the Driver Log is attached. There are 2 options for the setting "Trigger program calls on the robot", "Always" and "Only if the program is not available in RoboDK". I tried both options, and both options produced the same error and disconnected from the robot.
I verified that the program call was exactly as you described it in the post (no spaces), so this solution does not appear to work properly.
I will also note that when I run Prog7 for the first time, the robot makes the first move then stops and never continues. The status of the robot shows working for a minute or so then goes ready but never executes the next command. I disconnect and reconnect the robot and rerun Prog7 and it does run to completion (or at least until it gets an error running the program call).
