Post Edit for KRC4 with Sample CSV code
I recently acquired an RMC10 robot cell from Robotic Solutions including a KR10 R1100-2 and rotary with tool changer. My workflow is Rhinocam to RoboDK and they recommended reaching out to finalize the post-processor. I have a sample CSV code with parameters I need to pump into the post. Are there any resources or services to create this post? In the meantime, attached is a sample src with 2 tool changes for reference.  Any info is much appreciated.
.txt   csv.txt (Size: 21.38 KB / Downloads: 365)
The workflow should be to load the CSV file in RoboDK as a program or as a curve first. Then, you can generate the program using an existing post processor for KUKA.
It looks like you have XYZABC values, speed and tool values in your CSV file.
For example, to load list of targets you can find this script which you can easily customize:
https://robodk.com/doc/en/PythonAPI/exam...ram-xyzwpr
You can also load the list of targets as a curve or an NC files and convert it into a simulation and a robot program:
https://robodk.com/doc/en/Robot-Machining.html
Thank you Albert. I really appreciate the info to get things up and running. The folks at Robotic Solutions speak highly of you.
I went to run script and ImportCSV XYZWPR and receive the following error attached. My apologies, I'm unfamiliar with Python
Thank you for your feedback. The load script I mentioned was designed for a CSV file formatted using comma as the separator. Your file has a semicolon as a separator. It is also not structured the same way.
To adjust this you can use a script like the one attached instead in the RoboDK project file called ImportCSV KUKA. I also added a script called ImportCSV Curves which will only load the curve. The difference is that with a curve you can change more settings in RoboDK. It would even be better if you create your custom NC file from your CSV files.
For the scripts to work I removed the header information inside your CSV file. Also, it looks like you have a very long approach to your part that should be removed. I recommend you to adjust the approach and retract settings in RoboDK.
To use this script you can follow these steps:
  1. Copy the scripts in your project.
  2. Double click on the file to run it (ImportCSV KUKA to import as targets, ImportCSV curve to import as a curve).
  3. Select the CSV file. Make sure it is a CSV file with a similar format (without the header information).
.txt   csv.txt (Size: 20.34 KB / Downloads: 222)
.rdk   Sample-Load-KUKA-CSV.rdk (Size: 1 MB / Downloads: 319)
Thank you Albert. I seem to be running into an issue as things aren't looking quite right after following those steps. I attached my test file for any suggestions.
Let me know if you have any thoughts to clarify. Much appreciated.
-Tim
What you see at the end of your program where the turntable stops and the tool tries to continue to move following the path is a common issue that you reached the limit of the turntable. You can simply extend the limits by a factor of 100.
Also, you should place the part in a coordinate system held by your turntable and select it in your robot machining parameters.
You can also speed up the calculation if you set the parameter Allow a tool Z rotation of +/- 0 deg instead of 180. By doing this, your last machining operation (axis parallel) should be created in less than 10 seconds (as opposed to probably 2 minutes).
Another detail: I used the simplify mesh Add-in to reduce the size of the 3D model. It was way too detailed which was creating a heavy part to display and to save as a RDK file. I used the default settings and the mesh size was reduced by 80% approximately. You can find this Add-in here:
https://robodk.com/addin/com.robodk.app.simplifymesh
See attached image and project with these changes.
.rdk   Pogany-TEST-v2.rdk (Size: 34.81 MB / Downloads: 342)
This is great and very helpful. On that topic, is there an unlimited setting that can be applied for unlimited turntables? I've maxed out the sliders in testing.
Lastly, can you cross check my ImportCSV KUKA scripts in the attached file? I edited to remove the original csv formatting. Im receiving a long circular spiral curve. If this is the long approach you were mentioning prior, I will circle back with my integrator on why this is in the csv.
Thank you again
.pdf   RMC10Script.CSV - Sample.CSV.pdf (Size: 38.95 KB / Downloads: 227)
Can you provide us with the original CSV/TXT file? You can upload it as a ZIP file if you are having issues.
I'm assuming the header could be different and the columns may map the values differently.
Yes of course. Attached in the Zip is the CSV values provided by Robotic Solutions (without headers).
I also packaged some additional info they provided including:
-5 additional commands for the output code as shown in SampleRough.src...
TOOLCHANGE9(1)
BAS(#TOOL,1)
RSIBASE(1)
SetRPM(12000)
Clear2Home()
-A main runner sample program: CompleteProgram.src
-Option to call one or more csv files: CsvFormat.src
Ultimately this is what Im trying to achieve when generating the program. Im milling complex mesh surfaces with relatively large file sizes. Thank you again for taking a look.
.zip   RS-Parameters.zip (Size: 51.4 KB / Downloads: 304)
Here are the values to pull from the origianl csv (I forgot to include)
Column #1 = Line number
Column #2 = X-Coordinate
Column #3 = Y-Coordinate
Column #4 = Z-Coordinate
Column #5 = A-Rotation
Column #6 = B-Rotation
Column #7 = C-Rotation
Column #8 = Line number
Column #9 = Feedrate in Meters/Second. This is the robot speed.
Column #10 = Spindle state. (ON = 1/OFF = 0)
Column #11 = Spindle speed (RPM)
Column #12 = Spindle rotation (CLW=1/CCLW=0)
Column #13 = Coolant (ON=1/OFF=0)
Column #14 = Tool Number.
Column #15 = Linear Slide Axis value.
Column #16 = Rotary Table Axis value.
Column #17= Always make this 0
Column #18= Base Number
Column #19= ALways make this 0
"Column #20= MoveType(0-Joint Angles, 1-Cartisian, 2 Circular, Cartisian PTP)"
Column #21= Total Number of Lines in file.
Column #22= Arc Midpoint X Value
Column #23= Arc Midpoint Y Value
Column #24= Arc Midpoint Z Value
3 Guest(s)
