Robot Positioning
        I had calibrated the joint values of mine 6-axis robot and exported them to RoboDK, but in simulation the robot is crashing. The position of the robot is completely different compared to real robot. How can I correct the robot position in RoboDK?
with regards,
Nikhil Kumar Maniyanthotil
Ok, there's something wrong here for sure.
Can you do something for me?
Bring the robot to its home position, take a picture of the robot, and a picture of the joint angles on the teach pendant.
Move the 3, 4, and 5 by something like 30 degrees, take a picture of the robot and a picture of the joint angles on the teach pendant.
We should be able to solve all of that pretty quickly.
Sorry, for the late response. I had to wait a couple of days to run the robot. Here in this mail you can the Link which contains the pics of the robot and its joint values(U,R,B)/ (3,4,5).
with regards,
I'm having the same problem as yours and don't know how to fix this
This issue is specific to Yaskawa Motoman robots.
You should make sure you properly enter the pulses/degree ratio in RoboDK. More information here:
https://robodk.com/doc/en/Robots-Motoman...omanPulses
