We are small producer of 6-DOF collaborative robots looking for robot calibration solution. In the RoboDK documentation, in the Accuracy section we see lot of possibilities: TwinTool, TwinTrack, Laser tracker support, Optical measurement systems... What measurement system is best to calibrate a robot? What data do we obtain after the calibration process? How should we apply it to the robot controller? What licence do I need for calibration?
Robot calibration questions |
03-10-2023, 12:58 PM
For accurate robot kinematics, you will need to perform robot calibration with a laser tracker or optical CMM.
https://robodk.com/robot-calibration It requires a RoboDK Professional licence, with the Calibration option. https://robodk.com/pricing The process and results can be found in our documentation: https://robodk.com/doc/en/Robot-Calibrat...acker.html Contact us as https://robodk.com/contact for more information!
Please read the Forum Guidelines before posting!
Find useful information about RoboDK by visiting our Online Documentation.
03-10-2023, 01:18 PM
(03-10-2023, 12:58 PM)Sam Wrote: For accurate robot kinematics, you will need to perform robot calibration with a laser tracker or optical CMM. 1. So Twin Tool is not for calibration? What it can be used for? 2. How much Calibration option costs? 3. What laser/optical solution is cheap and good enough to have 0,5mm accuracy for 6DOF, 1700mm reach robot?
03-11-2023, 04:15 AM
(03-10-2023, 01:18 PM)maciej.szulc Wrote: 1. So Twin Tool is not for calibration? What it can be used for?
| 1 Guest(s) |
Powered by MyBB
